RCU Forums - View Single Post - glueing question please help
Old 12-26-2004 | 10:28 AM
Rodney
Default RE: glueing question please help
Just a tip, if you are new to CA's, remember that CA does not like an acedic base which is what most hardwood and plywood are. To make a good CA joint on them, use some baking soda (like used in the kitchen) and very lightly dust the area to be glued with baking soda before adding the CA. Viola, instant and good joint but is nearly unsandable so do not leave any mounds of soda you would have to remove later. You will find baking soda to be one of your necessary aids if you use much CA.
