RE: prop balancing
The Windsor prop balancing system uses a jig that one slides about the hub location until the balance center is found. Then a drill bit is run down through the jig to relocate the hole.
You need a jig with center holes the size of each prop shaft diameter you are going to use...
Enjoy,
Jim
