RE: GET the LEAD OUT !
the push rod is fine i use it on a cap 232, edge 540 and extra 230 all around the same size as the lanier and have flown the lanier on the push rod set up as long as the push rod is still enough it will be fine wit ha pound of weight on the nose it flies like you left the wing off
