RE: Truckzilla Advice Wanted
Does the oneway bearing casing have a crack in it? If it does not it might still be good and just needs to be cleaned out sometimes they get oil in them and it makes them slip clean it out and try it again. Also be careful you don't flood the motor when you prime it. To make starting the motor easier heat it up with your blow dryer for about 2 min before you fire it up. You should not have to pull that hard with your plug loosen , loosen the plug by 1/4 0f a turn next time.
