RCU Forums - View Single Post - Gear differntial problems
Old 12-27-2004 | 05:54 PM
Carnutz68
Default RE: Gear differntial problems
Did you tighten the diff screw inside the outdrives.
If not tighten it snug then back it out till you can turn one outdrive one way and the other turns the oppsite way, then adjust as needed after you run the car. (hold the gear in one hand and turn with the other) Hope this helps...
