Hello John
If you want to make one I used the National Semiconductor LM1048 adjustable regulator. It is good for 5A and with a good heat sink I have used it on my mw 54 with Eco fadec on it. I ordered it from
www.digi-key.com. Im working on trying to make a parallel one for 10A but I’m still learning circuit design and electronics. [sm=drowning.gif]
If Gaspar says it can handle then it must be good to go.
Gaspar just a few questions and you can PM me if you want.
1. How may steps does the ECU use to control the turbine.
2. Do your different ECU's have different amounts of pump steps for throttle control.
3. What is the acceptable top % of pump steps for full throttle for smooth control of the turbine?
Thank you for making a great ECU Gaspar! im converting my old RAM 750 to Fadec next.
