ORIGINAL: colindecon
ok i just took it apart and its not the oneway bearing its the pin and the bit it turns with , it has a chip in it and is making it not lockin when turning???????? the engine has not been running for more than 2mins?? can it be a manafactors fault????
................Is the chip on the end of the crankshaft where the pin sits in? Because if it is then you need to send the crank back to hot bodies and get a new one should be covered under warrenty. There is a spring behind the pin did you find that?
