RE: 130 Flaps
The stab is where I had the biggest problem and it affected flying seriously.
I would use the flat portion of the wing saddle on the fuse. as a reference point.
NOTE: I used the Robart indicent meter for this work.
1) Use the flat saddle and level it using a graduated level.
2) Take the horizontal stab and attach it to the stab saddle.
(I had drilled my 2 nylon mounting bolt plates and use the nylon bolts)
3) Shim the leading edge of the stab for a MINUS 2 Degrees.
(I know you are asking Minus? but consider if the stab is Minus 2,, when the stab is ZERO the wing is at +2 Degrees,
The +2 Degrees has worked well on mine and I experimented from - 2 in 1 degree increments until I reached +2)
4) Mark the leading edge of the stab on the fuse and this will give you a reference to mount the stab.
The Leading edge bottom of the stab was just about flush with the bottom of the fuselage where they touched.
Hope this helps. I would consider this a critical step.
Jim
