45 degrees each way is a good starting point, some planes need more and some can get away with a little less.
I use around 20 to 40% expo depending on the plane.
I fly using this rate all the time, no DR switch.
For the maiden flight I use a lower rate but have the normal 3D rate ready just in case I need it, which I haven't. Just an old habbit
