RE: YS Engine question
Jim, unfortunately the crank will have to be replaced. THe threaded portion is actually part of the crankshaft. I would suggest sending it to YS performance. THey can replace the crank and check to see if it needs anything else replaced. You may want to call them for an estimate on the crank. It may be cheaper or more benificial to replace the engine with a new 63.
Good luck. Bob
