RCU Forums - View Single Post - Batshare Question
Old 12-28-2004 | 06:56 PM
evo50
Default RE: Batshare Question
I'm finishing my first big bird a Midwest CAP232 80 with way to much $$ in it and want no issues with power problems. So here goes some questions I need help with.
Should I go with the 'batshare' vs. just using two batterys, two regulators and two switches?
If I use the batshare will I need two regulators or one?
I'm using Hitec 5625/5645 servos, should I regulate them at 6.0v or 5.4, the instructions say they work on 6v?
Why is the batshare better than a simple double up on things right to the RX. If both batterys are of the same capacity and voltage then how is the batshare better as using this setup the batterys cannot charge each other?
Is there a system such as the batshare with the regulator built in?
I'm on a budget here my wife has cut me off so any help is appreciated.
Bill
