RE: Quick Help Needed!
To tin the wire before soldering it to something you heat the stripped wire with a hot iron and melt a little solder into the wire. Do the same thing to the connector pins, heat it up and melt a little solder onto it. When you have two tinned surfaces you can just heat them up until they melt together. Thats why you dont want to plug connectors together when you solder them, they will get soldered together.
