Well I suppose it would be crazy if used without some common sense
It is nice to have plenty of power reserve, you can do some neat tricks not possible with lower power. The lower rpm did catch me out a little at first, the HS velocity being much higher than the powerplant noise level would suggest, but you do quickly adapt to the different throttle management required.
