RCU Forums - View Single Post - Towerkote??????
Old 12-29-2004 | 01:18 PM
Campy's Avatar
Campy
Default RE: Towerkote??????
You may want to take a look at UltraCote. It is a LOW TEMP film covering that a lot of people prefer over MonoKote. Unlike Econokote/Towerkote, it is as strong as Monokote, the adhesive is fuel proof and it goes around corners/curves a lot easier than Monokote.
Somethings you should keep in mind when using any film covering (and a lot of fabric coverings also ).
First, what you need to do is apply the covering as tightly as possible initially so the initial shrinking can be done at the lowest possible heat for the product used.
Covering begins to shrink at a certain temperature. If (when ) you need to reshrink it you must use a higher temperature for it to shrink some more.
At some point the covering is not going to shrink any more.
IMHO, if you can start shrinking the covering at a lower temperature, you have more "room to play with" for those stubborn wrinkles and/or reshrinking later on.
