RCU Forums - View Single Post - Rolling Harriers -- The New Technique
Old 12-29-2004 | 01:44 PM
  #43
uby's Avatar
uby
Default RE: Rolling Harriers -- The New Technique
Well keep the YS 160 ready for me.
Yes I have done a rolling loop without rudder on Hanno Prettner's Magic.
What I am talking about is my 3rd flight on the sim. I AM NOT PERFECT YET , but If I practice more I can be perfect. (Please donot compare me with the TOC guys I am too novice infront of them) Now there are two files in the recording directory. one is *.shd file and the other is REC file .... if i attach the .SHD file will it work ? 'cause the REC file is a bit large to upload.
One roll rolling circle or slow roll rolling circle cannot be accomplished without rudder of course but I've seen people do that too. Guys I am not negating the importance of rudder , of course its integral part of all flying and its not that I donot use rudder at all, it is required in every manevour but this technique for rolling harriers also works well. You guys should atleast once try it both ways. Use the roland matt's extra with 60 degree deflection on all surfaces and at about half throttle.
ORIGINAL: 3D ONdaEDGE
You have run into a problem though. Although your method for rolling harriers works, It WONT WORK for rolling circles,and it WONT work for PERFECT rolling harriers like you stated earlier. YOU CANNOT do a PERFECT rolling anything without rudder. I repeat, CANNOT. Lets take for instance your average 4 outside roll rolling circle. It is very important to not only use the rudder while in knife edge, but also in level or inverted flight to turn the aircraft. The same goes true with a Rolling harrier, but really isnt as important since the planes are rolling so fast. All the TOC guys use slightly different tecniques, but basicall all the manuvers are done the same way. Oh, and ALL of the TOC and XFC and whatever else guys use rudder while rolling.
3D ONdaEDGE .... there is no term "Impossible" in my dictionary. You CAN do PERFECT rolling harriers if you practice. Though I cannot do them PERFECTLY right now but very soon, by the grace of Allah,.... I'll be able to do so.
So guys tell me about the video what file to upload ?
