RE: Help Huge wing loading
Yes know about that. Gyroscopic pressesion off big blades. Will have gyros in pitch and roll helps a lot per V22 chap. Still you will need enough airspeed to make the tail effective to contrll pitch. The V22 uses an inverted flat bottom air foil for Horizontal Stabilizer .Thanks for the thought its a big issue you normally wouldnt consider.
