RCU Forums - View Single Post - installing engine bearings
Old 08-29-2002 | 12:02 PM
IronCross's Avatar
IronCross
Default installing engine bearings
You should not have to "force" the bearing in. You may damage the case that way. Just heat the case in the oven, then with with bearing on the crank it should drop right in. Then drop the front one in.
If you force it you run the risk of loosening the bearing to case fit and when the engine heats up while running there is a risk of the bearing spinning out. At this point the engine is not much good.
