RE: vectorflight extra 300 trim covering and wing joining
Bumstead, looking further at the website here is what he has to say
" Since shorts rarely occur in fully charged packs the risk of one pack "dumping" into one with a shorted cell are insignificant. A simple ESE preflight test would detect a pack with a shorted cell.
While it is a fact that the typical failure mode of a battery is for a cell to fail shorted there are some subtleties here that escape many people. First,one of the major causes of "battery" failure has nothing to do with the batteries themselves but rather with a switch or connector in the battery circuit. The dual redundancy concept is to protect against the failure having the highest probability - that being the circuit path from the battery to the power buss in the receiver. Adding more components to this path, like regulators and/or diodes isn't going to help the matter but rather adds to the probability of failure.
Perhaps the following discussion on the nature of shorts will better help the modeler understand.
While it is agreed that shorts are the failure mode in Ni-Cds batteries one has to look further into the "when" of the failure.
A short develops in a Ni-Cd when conductive particulate bridge the separator or the separator itself deteriorates to the point where it allows the positive and negative plates to touch. Rarely does the short occur all at once but rather building up a very small conductance path termed "soft shorts". In a charged cell the energy in the cell will blow away any short as it tries to develop. You've heard about "zapping" cells. The cell actually zaps itself before the short can develop. Only in cases of severe overcharge at high rates can the separator melt down to the point where the plates contact each other (hard short). In this case the energy in the cell then dumps and we have what is referred to as a hot steamer, the electrolyte boils, nylon in the separator melts down and is forced by the steam through the vent. On some occasions the vent is clogged by the molten nylon separator and becomes inoperative causing the cell to rapidly disassemble. So under normal circumstances a cell maintained at some state of charge is much less likely to short than a cell that is completely discharged. It should be noted however that the self discharge increases rapidly in cells where there is a short building (high resistance -soft short) due to separator deterioration and/or cadmium migration. One other shorting mechanism is a manufacturing defect where the positive or negative collector tab bridges the opposite plate. These usually fall out before the cells are shipped or assembled into batteries.
Preflight procedure should involve checking each battery separately. First check each with ESV through charge jack. You should get nearly identical readings, then switch one on, check controls, switch off and then switch on the other battery, check controls again, then turn both systems on and fly with confidence."
So if someone didnt check BOTH packs before a flight then the diode would eliminate that risk.. although a relatively small one.
I guess thats why its good to know, if you want to elimante the risk, check the batteries or install a diode.
