Removing Wrinkles
I will soon have two airplanes in my hangar after I get the second one built. I just got an iron and was going to try and remove some wrinkles in both models. One is covered in Ultracote and the other one is Monokote. I have heard that Ultracote uses a lower heat setting......300 degrees???? How about Monokote for temperature? Also, do I have to be concerned about having the iron to long in one spot and ruin the covering? I do have a sock for my iron.
Thanks to all.
