Hey guys,
Sorry but I didn's get to the plane yesterday. The kids and New Year's Eve kind of took over my evening
Jon, here are the measurements for my PVC stand. Of course you should change any of the dimensions to suit your needs. I used 3/4" PVC pipe for the entire stand. I like it's light weight and sturdiness. The 2 middle tubes are 30". The legs are 4.5". The cradle pieces are also 4.5", but you can make than any size you need to accomdate larger aircraft. I also used 4 - 45 degree elbows for the feet, 4 - T-fittings that connect the legs to the middle support tubes, 4 - x-shaped fittings that connect the lower portion to the cradle. Here are a couple of pics of the stand alone. Hope this helps.
Luke, thanks for the servo placement idea. That was one area that I was scratching my head wondering where to put it. Hopefully I will be able to get to the plane some. We are having a New Year's Day dinner later on and I know I won't be able to do anything to it then.
Until the next update....
