RCU Forums - View Single Post - Composite ARF Impact
Old 01-01-2005 | 02:03 PM
  #287
Derek.Koopowitz
Default RE: Impact
ORIGINAL: Andy P.
If you go to page 8 of this thread you will see my posting on how I set my Incidences, also if you follow that method the stab incidence will be zero and the fuz will also look as though it's at the correct flight attitude. Hope this helps.
Andy,
I'm very close to "glueing" everything for my stab so I just want to make sure that I've understood you correctly...
Extended a line from the top of the chin cowl all the way back to the stab (30mm below the middle of the stab tube) - using this as my "center line". Propped up the model so that this line is perfectly horizontal from nose to tail and then I set the stab incidence to 0 based on this reference point.
Am I correct in my assumption of your writing?
[sm=thumbup.gif] or [sm=thumbdown.gif]
-Derek
