RCU Forums - View Single Post - servo extensions??
Old 01-01-2005 | 02:51 PM
OhD
Default RE: servo extensions??
The Glitch Buster comes from EMS-Jomar and the regulators are custom Jaccio that you can get from me if you want to try this system. It is far cheaper than these power distribution boxes coming from Germany and you still have to worry about voltage drop in the long extensions with those devices. You also need to plug in multiple aileron extensions with those because you wouldn't want to us a Y harness in the wings like I do. The regulators weigh less than a half ounce and cost about $10 each. I have 8 of these plus a standard 5 amp regulator to power the receiver, throttle servo and engine kill switch. I make a simple mod to the GB so the pulse amplifiers run off the regulated 5.7 volts instead of the raw Li-Ion 8 volts.
ORIGINAL: bhanley
OhD - where do you buy the Glitch Buster and the regulators. Also,
what do the regulators weigh??
Bruce
