RE: pros and cons of 2 and 4 stroke engines ?
tIANci
I'm not sure the fuel tube between the carb and needle is new. The two engines are OS .50 and Super Tiger's engine which all of them eliminate the fuel tubing.
Also if you are eliminating a tube then this has to be better for the pressure in the fuel tank and in the cylinder. Have you flown a plane with both set ups?
I'm going to order a new engine and really need to now the performance difference . Thanks [8D].
