RCU Forums - View Single Post - Composite ARF Impact
Old 01-01-2005 | 08:00 PM
  #288
MTK
Default RE: Impact
Derek that's the same as placing a 33.5 mm block under the tail post, with the front of the fuse blocked up as Andy says. The fuse bottom will need to barely touch the building surface. That's is the correct factory fuse angle for things to work out correctly in knife edge. The stab needs zero and the wing about .25 positive.
MattK
