RE: is my engine possessed
The head gasket will usually be made of copper. It's a thin ring about .010 thick. Without it, you'll raise compression, which will advance ignition timing, which will cause preignition, which will cause piston, rod and cylinder damage. Make sure it's there, and if it's not, get one.
