RE: pros and cons of 2 and 4 stroke engines ?
With the needle mounted on the carb, there are less places to develop air leaks. Also brings your knuckles very close to the prop. Rear needle engines are sometimes more difficult to mount due to the rear needle not allowing the engine to be mounted as far back as you might need it to before coming into contact with the firewall.
