RCU Forums - View Single Post - Servo Wire
Thread: Servo Wire
Old 01-01-2005 | 10:48 PM
Fastsky's Avatar
Fastsky
Default RE: Servo Wire
A flying buddy has a WM Dago at our field. I strongly suggest you do not attempt to fly this as a second plane!! It takes good tail dragger experience just to get the into the air safely. Once up there the plane is a pretty quick flyer and can bite you in a hurry if you make a wrong stick movment. Ie. touching the rudder stick while turning with ailerons will instantly put the plane in a spin! Hopefully the TIger 60 is set up as a tail dragger to at least get you a bit prepared. For learning how to land the Dago, learn to land the Tiger at higher speeds. It will float in, but you want to learn how to keep the speed up. The Dago will stall if you slow it down too much for landing. [8D]
