Hi Pattern Student,
I'll put up some more pictures here and I will have better ones tomorrow. I have the wing together now so I can mount the belly pan. The pipe will clear the fuselage past the wing. The pipe is on a downward angle to do that. You could leave it flat and modify the fuselage further back but I don't see that it is necessary. This way the pipe is more in the breeze for cooling. Does anybody see a down side to this?
Question for AeroBob. Did you mount the belly pan with silcon sealer as the manual states to do or cut the covering and epoxy the belly pan on?
ORIGINAL: Pattern Student
Hey olddogg60,
Thanks for the pix of the TT120/pipe set-up. Do I correctly understand that you did NOT have to do any surgery to the fuse behind the wing T.E. to clear the pipe exhaust? I can't quite see what I think I want to see from the pix.
