Bipes seem to run more in general. Your looking at 2 wings. If you figure the time it takes you to build a plane wings/fuse then turn around an build another wing then cover it etc etc You can start to see where the etc dollars come from. Look at it this way your giving some chinese guy a few more hours work.
Ok, I see your point. [8D] But, there cann't be much wood in them wings if the plane as a whole is
1lbs lighter and more wing area than the Kat .70. That or the fuse filled with hot air.
Of course the fuse is shorter. More savings there. OK. I am starting to see where this will work. But I still think $239 is too high. [&o]
