RE: DA-50R vs BME 50
If you slam the throttle open with throttle coupled advance using a high speed servo, it seems likely that you'd get too much ignition advance at low rpm. In this case, electronic advance coupled to the rpm of the engine should provide the optimum ignition advance.
