ORIGINAL: Andy P.
I have chosen the rear tail servo set up without the tail incidence adjusters, the models c/g came in as close to perfect as you could wish. If you go to the comp-arf.co.uk site that Mark Shroeder has created, you will see the photo's of the set up method I posted earlier, well done Mark!!
One other thing... on your tail servo setup... did you mount them inside the stab or do they protrude into the fuse? How did you epoxy that balsa brace in the rear? There is no access except through the tail post...
