RE: Epoxy Wing
Hi!
What you do is to smear 5min epoxy on the spar. Then put the two winghalfes together...using masking tape, cross over the wing joint and at the same time checking so that the root wing spars fit nicely...and then pour on thin CA glue at the wing joint!
Regards!
Jan K
Sweden
