RCU Forums - View Single Post - Finished!!!!
Thread: Finished!!!!
Old 01-02-2005 | 06:37 PM
CafeenMan
Default RE: Finished!!!!
If you have a good, low idle and the plane is still rolling you can maybe use a lower pitch propeller depending on what you're using now. You can also try tightening up the wheels a little if you take the time to make sure both wheels are the same and not so tight that the plane noses over.
Nice job on your first build!
