RCU Forums - View Single Post - Creek Hobbies Studacher - Construction Notes
Old 09-06-2002 | 02:47 AM
Loopman
My Feedback: (195)
Default Studacher Update
Just finished installing the horizontal stab and wing tube. The stab fit was very good but required some adjustment to get both sides level. Did this by installing the stab with 2 hour epoxy and using small plywood shims under one side to get them both level with a flat surface. We then installed the wing tube and included tube supports. This was definitely a two man job and I was glad to have great help from one of my fellow club members. With an extra pair of hands this went very smoothly. The wing incidence was then measured and very little adjustment was required to get the required zero reading. A credit to a well constructed airframe! The wings butted up to the fuse sides with no gap!
One correction to the review done by Erick Royer though. The spinner diameter is 3.5 inches instead of the listed 3.25. A small matter but if you're buying an aluminum spinner you definitely want the right size the first time out, those things are expensive!
That's all for now!
Happy Flying!
LOOPMAN
