Thank you Creek Hobbies! This is one solid aircraft. The Super Tigre 2300 is really too much engine! I fly all aerobatics at about 1/2 to 3/4 throttle. I had a H9 Cap and it does'nt even compare! Take off in about 25 feet straight up after that. Loops and rolls very stable. Four point rolls with very little elevator. Will hold knife edge easily. Enough bullet statements!
Landing this plane is the trick. You need to start bleeding airspeed as you turn onto final. Make sure that once you've got the threshold made you keep a slightly nose high attitude. If the nose drops the slightest bit she picks up speed. This is all due to the fact that this plane is extremely aerodynamically clean!
In a nutshell, this is a great ARF and well worth the money!
Happy Flying!
LOOPMAN
