RE: Epoxy Wing
I tape the joint, then stand the wing up in a corner with the upper panel flat against the wall and teh lower panel at the correct dihedral angle away from the wall. Has worked very well so far, the only down side is if you don't get all the epoxy cleaned up right away it usually runs halfway down the wing before it cures.
Andy
