RCU Forums - View Single Post - My JetMart USA F-14 Almost Finished
Old 01-02-2005 | 10:24 PM
rcjetfan
Default RE: My JetMart USA F-14 Almost Finished
Adil, your markings and TCS chinpod are correct for the Alpha version of the Tomcat "Vandy 1". If your going the Delta version you need to make quite a few modifications, like dual chinpods, ecm blisters above the intake, different engines from the P&W TF-30 to the GE F-110. If your doing a Delta you will also need to change your markings. This is Vandy 1 the plane you are doing which was with VX-4
