RCU Forums - View Single Post - Epoxy Wing
Thread: Epoxy Wing
Old 01-02-2005 | 10:55 PM
freebird1
Default RE: Epoxy Wing
I do mine just like raideron. Put the epoxy on heavy. Put toghether. remove the extra with 90% alcohol. Tape together and use clamps. I have even used cloths pins. In 20 Mins I remove the tape and any expoy I may have missed with the 90% or has made its way out. Standing is good if you can get close to a 90 degree angle, if not when you check the wing will may not be flush.
Good Luck
