RCU Forums - View Single Post - starting problems
Old 01-03-2005 | 04:08 AM
Tyre pressure
Default RE: starting problems
Start at the fuel tank and check for blockage, check fuel lines for blockage.
Make sure you have no holes in the lines so that you are leaking fuel.
is the cylinder head moving up and down.
Base settings are in the manual.
Make sure you unscrew the glow plug half a turn when starting up... this will make it easier for you to get her going.
