RCU Forums - View Single Post - prop position
Thread: prop position
Old 06-12-2002 | 01:17 PM
BobbyRichardson
Default prop position
Originally posted by Cyclic Hardover
If your engine quits in flight, the prop will rotate backwards to the point of compression. This is where i set mine so that if i go into the weeds or whatever when the engine quits, my prop will stop at a horizontal position, thus saving the prop.
To get your prop to stop at this desired position how would you install it on the crankshaft?
