RE: Engine won't quite start
With the carb you mention there should be very little possibility of hidden gunk in it. I think the worst problem would be the "O" ring on the low speed needle or the low needle set too lean. All the 6550s being run in this area also do not like the Fox plugs, but prefer the original equipment K&B R/C plugs with idle bar.
