RE: Epoxy Wing
You are correct about the spar supporting the weight. That is why you should never glue two wing halves together using thin CA (or any CA for that matter). In a two piece wing, the root is the only place where the spar is not continuous. In other words, for weight and force to be transfered back and forth between the spars, the joint holding them together must be at least as strong as the spars, or you have a weak point!
