Hi Driftair...After viewing Tahustvedt's video it appears that only XTR can do the Monkey flip physics correctly[sm=thumbup.gif]. No one else will post a video with another simulator[X(]. One of the 2 simulators I own is excellent for loops,rolls,harriers,elevators,hovers,knife edge,aileron torque rolling and high alpha maneuvers
. It does require aileron help for engine torque rolls? Neither of my simulators appear to match the correct tail slide physics of the Reflex simulator[
]. I hesitate in purchasing XTR because I have no idea how much the planes can be modified or if they will truly simulate a torque roll with engine torque. I know of no simulator that can flat spin using real inputs(cheater spins with non-realistic stick inputs work fine)however they look good. Some things one can do on a simulator will not work on a real model(a counter clockwise knife edge loop without throttling back on the down line will allow your plane to fit in a shoe box but works without a scratch on a simulator)[sm=stupid.gif]. Simulators have come a long way but still need some bugs in their physics addressed. If I find an XTR to try out, I may become an XTR convert. Correct Physics Rules in real flying!
ORIGINAL: driftair
[8D] Hi Bowser,
I have flown AeroflyPro, but not AFPD. I now own and have flown Reflex XTR.
I like the flying realisim of Reflex XTR better.
There are other qualities about AeroflyPro that I like alot, and Deluxe is most likely wonderful but my guess is its flight response does not quite reach the performance found in Reflex XTR. Still, I would expect that AFPD may come close, but it is not as configurable.
***** Reflex XTR has a horrible USB Connection that takes up 2 USB ports !!! ***** This sucks and should be corrected !!!
Reflex XTR takes some getting used to and has many more configuration options than other simulators.
Other simulators ie: AeroflyPro Deluxe, and RealFlight G3, have some features that are more game like.
AeroflyPro and AeroflyPro Deluxe are very advanced in their flight response, but so far as I have experienced to date, not as accurate as Reflex XTR.
I like both simulators for different reasons.
A combination of the best qualities of AeroflyPro Deluxe, and Reflex XTR plus the RealFlight USB Controller (Made by Futaba) would create the best simulator on the market.
