RCU Forums - View Single Post - Guessing Down thrust...
Old 01-03-2005 | 03:37 PM
Patriot's Avatar
Patriot
Default Guessing Down thrust...
On my 80" BUSA Citabria Pro, the plans call for 1 Dgeree of Engine downthrust. But, many who have built it say it flies much better with 2-3 deg of downthrust.
I have installed an Enya 155R 4c, and had 0 degrees to start with. It of course flew as if it needs downthrust, so I have added the following....
Under the top mount bolts, I installed two 1/16" thick washers between the mount and firewall, and it definitely has downthrust now. But, I am wondering exactly how much? I appears to be a good 2-3 degrees, but I have now way of really measuring exactly, so I was wondering what you all thought from your experiences of adding washers to attain an angle. How much does it generally end up with when doing this?
Patriot
