RCU Forums - View Single Post - Composite ARF Impact
Old 01-03-2005 | 05:26 PM
  #293
tggilkey
Default RE: Impact
ORIGINAL: MTK
Derek that's the same as placing a 33.5 mm block under the tail post, with the front of the fuse blocked up as Andy says. The fuse bottom will need to barely touch the building surface. That's is the correct factory fuse angle for things to work out correctly in knife edge. The stab needs zero and the wing about .25 positive.
MattK
Hey MTK, Andy, and DerekK!
From the quote above can I assume that if I set the fuselage on the table and prop the tail up 33.5 mm that I'll get what I should? Haven't started yet but will soon and want to get it right!
Tom
