RE: Excelleron 90
Hey guys,
Keep me posted on your results using the TT 120rp. I'm planning to use one in a CG Finesse. I bench ran it with header pipe only and a MA 16x10 and it was turning a little more than 9,000 rpm. seemed to burble in the mid range a bit, but will wait till I run it with pipe to play with the pump adjustment. I'd like to know what kind of length you guys are using with the pipe. Are you using the extension piece that comes with the TT pipe kit? Thanks,
Steve
