you will be out getting your 2nd, 3rd.. before you know it
make sure you do the break in right, and use good fuel. get a temp gun (can pick one up for under $30) to make sure your running right (200-220F). also, not sure if it comes with one on your setup, but use a hump pack for the reciver, not the AA's if you can. the 6volts make a huge diff in the turing. to save money look at the marketplace for things that can be used like a charger and other parts. most of all, have fun.
