RCU Forums - View Single Post - Guessing Down thrust...
Old 01-04-2005 | 12:46 AM
Patriot's Avatar
Patriot
Default RE: Guessing Down thrust...
Ok, so with one big washer between the engine mount and the firewall, I should have a good 1/2-1 degree of downthrust. I am certain it is probably at least 1 degree, because you can really see the angle with the naked eye. The backplate of the spinner has dropped about 1/8" from centerline, so I'll give that a try. Unless you all have a better idea? Thanks.
Patriot
P.S. BTW, I named my cat "Campy", named after bicycle components..."Campagnolo".
