RCU Forums - View Single Post - Guessing Down thrust...
Old 01-04-2005 | 01:34 PM
Rodney
Default RE: Guessing Down thrust...
Why guess when it is so easy to measure? Just use the tangent function from your old high school trig class. Even most of the low priced calculators now have this function available. You know the distance between the lower bolt and the upper bolt holes for one side of the triangle and the thickness of the shim (washers) for the other leg.
