RCU Forums - View Single Post - DP 300L
Thread: DP 300L
Old 01-04-2005 | 03:08 PM
  #38
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: DP 300L
Are both your elevator and rudder pull pull?
ORIGINAL: baxternick
I just flew my edge for the first time this weekend with the DPM moki 2.10. I am using a Air Wild NX 20X8 prop, and running the engine rich as hell. Have around 1.25 gallons through it so far. So power is still a few gallons away. Even at this rich setting the plane hovers a bit under 3/4 throttle. I have my cg a 6" and have a bit of tail weight in it too. 6 ounces to be exact. I had 5 flights over the weekend and found the plane waterfalls, blenders, and inverted flat spins like its nobodys business! Great plane, and the 2.10 is a pretty good match. I guess if you really wanted some sick 3d a 50 cc gasser woudlnt be so bad though!
